DRAFT help
Using JMP > JMP Preferences > Fonts Preferences
Publication date: 01/13/2026
Fonts Preferences
Font preferences customize the appearance of reports, data tables, and scripts, including fonts, text size, and font style.
Figure 15.5 Fonts Preferences (Windows)
Table 15.5 Preferences on the Fonts Page (Windows)
Preference
Description
Text
Sets the font for the text portion of a JMP analysis report. The default setting is Segoe UI, 9 Point.
Heading
Sets the font for the column headers in an analysis report and a data table. The default setting is Segoe UI, 9 Point Bold.
Title
Sets the font for the title that is shown in all title bars. The default setting is Segoe UI, 11 Point, Bold.
Small
Sets the font for small text, which is used in the upper left corner of the data grid to show the number of columns and rows. The default setting is Segoe UI, 7 Point.
Mono
Sets the font that is used in the Script Editor and editor boxes for script commands. The default setting is Consolas, 10 Point.
Formula Editor
Sets the font for the expressions that are entered into the Formula Editor. The default setting is Segoe UI, 11 Point.
Annotation
Sets the default font that is used in annotations. The default setting is Segoe UI, 9 Point.
Axis
Sets the font that is used for the axis tick labels. The default setting is Segoe UI, 9 Point.
Marker
Sets the font that is used for alphanumeric markers. The default setting is Segoe UI, 9 Point.
Axis Title
Sets the font for axis titles. The default setting is Segoe UI, 9 Point.
Graphic Label
Sets the font for data labels in graphs such as marker labels or bar labels. The default setting is Segoe UI, 9 Point.
Legend
Sets the font for legend titles, values, and other legend text. The default setting is Segoe UI, 9 Point.
Graph Title
Sets the font for the main graph title but not the secondary title or footnote. The default setting is Segoe UI, 11 Point, Bold.
Caption
Sets the font for the caption element and also any caption-like text (for example, line of fit statistics and the box plot 5-number summary). The default setting is Segoe UI, 8 Point.
Data Table
Sets the font for displaying data in the data table. The default setting is Segoe UI, 9 Point.
Hover Label
Sets the font for hovering over a label. The default setting is Segoe UI, 9 Point.
Font Family
Select a proportional font. The font that you select is immediately applied to all settings except for Mono, which is used for scripts.
Use Greek letters
Select this option to use Greek letters instead of spelling out Greek letters (for example, π instead of pi.) This option is selected by default.
Use math symbols
Select this option to use math symbols instead of simple text representations of math symbols (for example, ± instead of +/-) This option is selected by default.
Figure 15.6 Fonts Preferences (Apple macOS)
Table 15.6 Preferences on the Fonts Page (Apple macOS)
Preference
Description
Text
Sets the font for the text portion of a JMP analysis report. The default setting is Helvetica Neue, 13 Point.
Heading
Sets the font for the column headers in an analysis report and a data table. The default setting is Helvetica Neue, 13 Point Bold.
Title
Sets the font for the title that is shown in all title bars. The default setting is Helvetica Neue, 18 Point, Bold.
Small
Sets the font for small text, which is used in the upper left corner of the data grid to show the number of columns and rows. The default setting is Helvetica Neue, 11 Point.
Mono
Sets the font that is used in the Script Editor and editor boxes for script commands. The default setting is Menlo, 13 Point.
Formula Editor
Sets the font for the expressions that are entered into the Formula Editor. The default setting is Times, 14 Point.
Annotation
Sets the default font that is used in annotations. The default setting is Helvetica Neue, 13 Point.
Axis
Sets the font that is used for the axis tick labels. The default setting is Helvetica Neue, 11 Point.
Marker
Sets the font that is used for alphanumeric markers. The default setting is Helvetica Neue, 12 Point.
Axis Title
Sets the font for axis titles. The default setting is Helvetica Neue, 11 Point.
Graphic Label
Sets the font for data labels in graphs such as marker labels or bar labels. The default setting is Helvetica Neue, 11 Point.
Legend
Sets the font for legend titles, values, and other legend text. The default setting is Helvetica Neue, 13 Point.
Graph Title
Sets the font for the main graph title but not the secondary title or footnote. The default setting is Helvetica Neue, 16 Point, Bold.
Caption
Sets the font for the caption element and also any caption-like text (for example, line of fit statistics and the box plot 5-number summary). The default setting is Helvetica Neue, 11 Point.
Data Table
Sets the font for displaying data in the data table. The default setting is Helvetica Neue, 13 Point.
Hover Label
Sets the font for hovering over a label. The default setting is Helvetica Neue, 11 Point.
Font Family
Use Greek letters
Use math symbols
