DRAFT help
Fitting Linear Models > Generalized Linear Mixed Models > Generalized Linear Mixed Model Options
Publication date: 01/13/2026
Image shown hereGeneralized Linear Mixed Model Options
The Generalized Linear Mixed Model red triangle menu contains the following options:
Model Dialog
Shows the completed Fit Model launch window for the current analysis.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
