JMP Live Resources
Publication date: 01/13/2026
JMP Live Resources
If your organization has purchased JMP Live, you can:
• Publish reports to JMP Live. See “Publish Reports to JMP Live”.
• Publish data tables to JMP Live. See “Publish Data to JMP Live”.
• Access the JMP Live installation help at https://www.jmp.com/jmpliveinstall.
• Access the JMP Live configuration help at https://www.jmp.com/jmpliveconfig.
• Access the JMP Live user help at https://www.jmp.com/jmplive.
• Access the JMP Live administrator help at https://www.jmp.com/jmpliveadmin.
• Access the JMP Live for SPC help at https://www.jmp.com/jmplivespc.
• Use the JMP Scripting Language to publish reports or data to JMP Live. See “Publish Reports or Data to JMP Live”.
