DRAFT help
Using JMP > Enter and Edit Your Data > Select Columns in Data Tables > Locate Next and Previously Selected Columns in Data Tables
Publication date: 01/13/2026
You can find the next selected column after the current column by selecting Cols > Column Selection > Next Selected Column. Similarly, you can find the previously selected column before the current column by selecting Cols > Column Selection > Previous Selected Column.
Each time that you select one of these options, the next or previously selected column appears and flashes. The options are available only when columns are selected.
You might want to use this feature to look at intermittently selected columns in a large data table.
