DRAFT help
Publication date: 01/13/2026
Image shown hereModel Fit Options
In the Generalized Linear Mixed Model report, each model fit report has a red triangle menu that contains the following options:
Model Reports
Enables you to customize the reports that are shown for the specified model fit. The reports that are available are determined by the type of analysis that you conduct.
Fit Statistics
Shows or hides the Fit Statistics and Model Summary reports that include information about the specification and goodness of fit statistics for the model. See Fit Statistics and Model Summary.
Random Effects Covariance Parameter Estimates
(Available only when there are random effects specified in the launch window.) Shows or hides a table of random effects covariance parameter estimates. See Random Effects Covariance Parameter Estimates.
Fixed Effects Parameter Estimates
Shows or hides a tabbed table of fixed effects parameter estimates. See Fixed Effects Parameter Estimates.
Random Coefficients
(Available only when there are random effects specified in the launch window.) Shows or hides a report of the estimates for the random coefficients. See Random Coefficients.
Random Effects Predictions
(Available only when there are random effects specified in the launch window.) Shows or hides a table of random effect predictions. For each random effect in the model, the report provides an estimate known as the best linear unbiased predictor (BLUP), its standard error, degrees of freedom, and a Satterthwaite-based confidence interval. Estimation of the standard errors requires calculation of the BLUP covariance matrix, which can be time-intensive. If the calculation time is noticeable, a progress bar appears.
Fixed Effects Tests
(Available only for models that contain at least one fixed effect.) Shows or hides the tests of fixed effects. See Fixed Effects Tests.
Empirical Standard Errors
(Not available if Multinomial is selected as the Distribution.) Replaces the standard errors with sandwich estimates throughout the report. This option provides robust standard error estimates that can be used to account for possible model misspecification. To use sandwich estimates in a multiple comparisons, inverse prediction, or stability report, you must select this option prior to selecting the other report option.
Tip: Selecting the Empirical Standard Errors option automatically selects either the Between-Within Degrees of Freedom or the Containment Degrees of Freedom option. Non-Kenward-Roger degrees of freedom must be used with empirical standard errors.
(Available only when the non-fixed effects in the model are all repeated effects.) Replaces the standard errors with unadjusted estimates and replaces the degrees of freedom to between-within based degrees of freedom throughout the report. To use between-within degrees of freedom in a multiple comparisons, inverse prediction, or stability report, you must select this option prior to selecting the other report option.
(Not available when the non-fixed effects in the model are all repeated effects.) Replaces the standard errors with unadjusted estimates and replaces the degrees of freedom to containment-based degrees of freedom throughout the report. To use containment degrees of freedom in a multiple comparisons, inverse prediction, or stability report, you must select this option prior to selecting the other report option.
Sequential Tests
(Available only for models that contain at least one fixed effect.) Shows or hides the Sequential (Type 1) Tests report that contains the sums of squares as effects are added to the model sequentially. Conducts tests based on the sequential sums of squares. See Sequential Tests.
Multiple Comparisons
(Available only for models that contain at least one fixed effect.) Opens the Multiple Comparisons launch window that provides various methods for comparing least squares means of main effects and interaction effects. For more information about the multiple comparisons options, see “Multiple Comparisons”.
Once you click OK in the Multiple Comparisons launch window, a Multiple Comparisons report is added to the GLMM report window. A new Multiple Comparisons report is added each time you use the Multiple Comparisons option. Each Multiple Comparisons report contains estimates of the least squares means, standard error, and a 95% confidence interval on the original data scale. The report also contains estimates of the means or probabilities, standard errors, and a confidence interval on the inverse link scale. You can change the α level in the Fit Model window by selecting Set Alpha Level from the Model Specification red triangle menu. This report is followed by the multiple comparisons test that you select. The All Pairwise Comparisons report provides equivalence tests.
Diagnostic Bundle
(Not available if Binomial or Ordinal Logistic is selected as the Distribution or if there are random effects in the model.) Shows or hides a set of four graphs, including a plot of residuals by predicted values, residuals by row number, a histogram of the residuals, and a histogram of the probability of observing a response larger than the observed response.
The Fitted Probability of Observing a Larger Response histogram helps you assess goodness of fit of the model. The “correct” model should display an approximately uniform distribution of values.
Conditional Diagnostic Bundle
(Not available if Binomial or Ordinal Logistic is selected as the Distribution or if there are no random effects in the model.) Shows or hides a set of four graphs, including a plot of residuals by predicted values, residuals by row number, a histogram of the residuals, and a histogram of the probability of observing a response larger than the observed response.
Marginal Model Inference
Produces profilers that are based on marginal predicted values. When the specified Distribution is Binomial, the predicted values are shown in terms of probabilities.
Profiler
Shows or hides a prediction profiler to examine the relationship between the response and the model terms, without accounting for random effects. For more information about the prediction profiler, see “Profiler” in Profilers.
Contour Profiler
Shows or hides a contour profiler to examine the relationship between the response and the model terms, without accounting for random effects. See “Contour Profiler” in Profilers.
Mixture Profiler
(Available only if the Mixture Effect attribute is applied to three or more factors in the model or the Mixture property is applied to three or more factor columns.) Shows or hides a mixture profiler to examine the relationship between the response and the model terms, without accounting for random effects. See “Mixture Profiler” in Profilers.
Surface Profiler
Shows or hides a surface profiler to examine the relationship between the response and the model terms, without accounting for random effects. See “Surface Plot” in Profilers.
Conditional Model Inference
(Available only when there are random effects specified in the launch window.) Produces profilers that are based on conditional predicted values. Conditional predicted values reflect both fixed and random effects. When the specified Distribution is Binomial, the predicted values are shown in terms of probabilities.
Conditional Profiler
Shows or hides a prediction profiler to examine the relationship between the response and the model terms, while accounting for random effects. For more information about the prediction profiler, see “Profiler” in Profilers.
Conditional Contour Profiler
Shows or hides a contour profiler to examine the relationship between the response and the model terms, while accounting for random effects. See “Contour Profiler” in Profilers.
Conditional Mixture Profiler
(Available only if the Mixture Effect attribute is applied to three or more factors in the model or the Mixture property is applied to three or more factor columns.) Shows or hides a mixture profiler to examine the relationship between the response and the model terms, while accounting for random effects. See “Mixture Profiler” in Profilers.
Conditional Surface Profiler
Shows or hides a surface profiler to examine the relationship between the response and the model terms, while accounting for random effects. See “Surface Plot” in Profilers.
Covariance and Correlation Matrices
Contains options to view the covariance and correlation matrices that are associated with the model.
Covariance of Fixed Effects
Shows or hides the covariance matrix for the fixed effects in the model.
Covariance of Covariance Parameters
Shows or hides the covariance matrix for the random effects in the model.
Covariance of All Parameters
Shows or hides the covariance matrix for all effects in the model.
Correlation of Fixed Effects
Shows or hides the correlation matrix for the fixed effects in the model.
Save Columns
Contains options to save various model results as one or more new columns in the data table. When the specified Distribution is Binomial, the predicted values are saved in terms of probabilities.
Prediction Formula
Saves a new formula column to the data table. The new column contains the prediction formula for the marginal mean. The column includes a Predicting column property that notes the source of the prediction.
Prediction and Interval Formulas
Saves new formula columns to the data table. The columns contain formulas for the marginal mean predictions and confidence limits. All columns are hidden by default except for the prediction formula column or columns.
Tip: The limits columns that are created by this option contain properties that are used by the Prediction Profiler. Select this option if you want to use these limits in the profiler.
Standard Error of Predicted
Saves a new column to the data table. The new column contains the standard errors for the predicted marginal mean responses.
Mean Confidence Interval
Saves two new columns to the data table. The new columns contain the lower and upper 95% confidence limits for the mean response. These intervals include the variation in the estimation, but not in the response. You can change the α level in the Fit Model launch window by selecting Set Alpha Level from the Model Specification red triangle menu.
Save Residual Formula
(Not available if Binomial is selected as the Distribution.) Saves a new formula column to the data table. The new column contains a formula for the marginal residuals, given in the form Y minus the prediction formula.
Conditional Prediction Formula
(Available only when there are random effects specified in the launch window.) Saves a new formula column to the data table. The new column contains the prediction formula for the conditional mean. The column includes a Predicting column property that notes the source of the prediction.
Standard Error of Conditional Predicted
(Available only when there are random effects specified in the launch window.) Saves a new column to the data table. The new column contains the standard errors for the predicted conditional mean responses.
Conditional Mean CI
(Available only when there are random effects specified in the launch window.)Saves two new columns to the data table. The new columns contain the lower and upper 95% confidence limits for the expected value from conditional prediction. The confidence intervals include random effect estimates for models with random effects. You can change the α level in the Fit Model launch window by selecting Set Alpha Level from the Model Specification red triangle menu.
Save Conditional Residual Formula
(Not available if Binomial is selected as the Distribution or if there are no random effects in the model.) Saves a new formula column to the data table. The new column contains the observed response values minus their conditional mean predicted values.
Save Simulation Formula
(Not available when a By variable is specified in the Fit Model launch window.) Saves a new formula column to the data table. The new column contains a formula that generates simulated values using the estimated parameters for the model that you fit. This column can be used in the Simulate utility as a Column to Switch In. See “Simulate” in Basic Analysis.
