DRAFT help
Publication date: 01/13/2026
Numeric Functions
In the JMP Formula Editor, you can create a formula that contains arithmetic operators that are commonly used in formulas. For more information about syntax, see “Numeric Functions” in the Scripting Guide.
Abs
Returns a positive number of the same magnitude as the value of its argument. For example, |5| and |–5| both result in 5.
Ceiling
Returns the smallest integer that is greater than or equal to its argument. For example, Ceiling(2.3) results in 3, while Ceiling(–2.3) results in –2.
Floor
Returns the largest integer that is less than or equal to its argument. For example, Floor(2.7) results in 2, but Floor(–0.5) results in –1.
Integrate
Integrates an expression with respect to a scalar value, using the adaptive quadrature method from Gander and Gautschi (2000). For example, Integrate( Exp( -x ), x, 0, . ) results in 0.99999999986846.
Modulo
Returns the remainder when the second argument is divided into the first. For example, Modulo(6, 5) results in 1.
Round
Rounds the first argument to the number of decimal places given by the second argument. For example, Round(3.554, 2) rounds to 3.55 and Round(3.555, 2) rounds to 3.56.
