DRAFT help
Design of Experiments Guide > Evaluate Designs > Overview of the Evaluate Design Platform
Publication date: 01/13/2026
The Evaluate Design platform provides powerful tools that enable you to assess the properties of your design, whether it is created by JMP or another tool. You can use the platform before conducting an experiment to evaluate your design or to help choose among several designs. You can also assess the impact of incorrect settings or lost runs in a design that you have conducted. You can modify the terms in your assumed model to see the impact of estimating a modified model. You can also modify the terms that appear in the Alias Terms section to see the impact on the Alias Matrix.
