DRAFT help
Publication date: 01/13/2026
Repeated Measures Degradation Report Options
The Repeated Measures Degradation with Random Parameters red triangle menu contains the following options:
Options
Contains the following option:
Save Posterior to Script
Specifies that when you save the script for the current report, the script contains the posterior samples. If you run the saved script, the posterior samples are loaded directly from the script into the Repeated Measures Degradation analysis.
Tip: Specifying the Save Posterior to Script option creates a longer script, but it enables you to reproduce the analysis in the future and saves computation time when you rerun the analysis.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
