DRAFT help
Publication date: 01/13/2026
Image shown hereResponse Gaussian Process Model Options
For each response, the Gaussian Process Model red triangle menu contains the following options:
Profiler
Shows or hides the prediction profiler. See “Profiler” in Profilers.
Save Model Fit Script
Contains options that enable you to save a script that exactly reproduces the Gaussian Process model fit that is reported in the corresponding individual response tab. This script does not reproduce any tasks that are performed in the Batch Selection tab. When the saved script is run, a new candidate set and batch selection are generated based on default settings.
Tip: Use this option if you are satisfied with the fit of a specific Gaussian Process model for one of the responses, but you would like to perform batch selection at a later time.
