DRAFT help
Publication date: 01/13/2026
SAS Integration Functions
As C Expr(x)
Description
Returns a C programming language representation of the expression.
Returns
A quoted string.
As JavaScript Expr(x)
Description
Returns a JavaScript representation of the expression.
Returns
A quoted string.
As JSON Expr(x)
Description
Returns a JSON (JavaScript Object Notation) representation of the expression.
Returns
A quoted string.
As Python Expr(x)
Description
Returns a Python representation of the expression.
Returns
A quoted string.
As SAS Expr(x)
Description
Converts an expression to a version that is more suitable for SAS DATA step. The code must be wrapped in a PROC DS2 call. Use Expr(...) for literal expressions. Use NameExpr(name) for expressions stored in a variable. Otherwise, the expression returns the expression to convert.
Returns
A quoted string.
Current SAS Connection()
Description
Gets the active global SAS server connection, if any, as a scriptable object.
SAS Export Data(dt, "libref", "dataset", <named_arguments>)
Description
Exports a JMP data table to a SAS data set in a library on the active global SAS server connection.
Returns
1 if the data table was exported successfully; 0 otherwise.
Arguments
dt
data table or a reference to a data table.
"libref"
the library to which to export the data table.
"dataset"
the name of the new SAS data set.
Optional Named Arguments
Columns(list)|Columns(col1, col2, ...)
A list of columns or a comma-separated list of columns.
Password("password")
A quoted string that contains the password to serve as the READ, WRITE, and ALTER password for the exported SAS data set. If the exported data set is replacing an existing data set with an ALTER password, this password is used as the ALTER password for overwriting the data set. If Password is specified, values for ReadPassword, WritePassword, and AlterPassword are ignored.
ReadPassword("password")
A quoted string that contains the password to serve as the READ password for the exported SAS data set.
WritePassword("password")
A quoted string that contains the password to serve as the WRITE password for the exported SAS data set.
AlterPassword("password")
A quoted string that contains the password to serve as the ALTER password for the exported SAS data set. If the exported data set is replacing an existing data set with an ALTER password, this password is used as the ALTER password for overwriting the data set.
PreserveSASColumnNames(0|1)
A Boolean. If true and the JMP data table originally came from SAS, the original SAS column names are used in the exported SAS data set. The default value is False.
PreserveSASFormats(0|1)
A Boolean. If true and the JMP data table originally came from SAS, the original SAS formats and informats are applied to the columns in the exported SAS data set. The default value is True.
ReplaceExisting(0|1)
A Boolean. If true, an existing SAS data set with the specified name in the specified library is replaced by the exported SAS data set. If false, a data set with the specified name already exists in the specified library; the export is stopped. The default value is false.
SaveJMPMetadata(0|1)
Includes SAS 9.4 Extended Attributed to store JMP metadata (such as table script and column properties). Default is 0 (disabled).
HonorExcludedRows(0|1)
A Boolean. If true, any rows in the JMP data table that are marked as excluded are not exported. The default value is false.
Notes
Information about the export is sent to the log.
SAS Get Data Sets("libref")
Description
Returns a list of the data sets defined in a SAS library.
Returns
A list of quoted strings.
Arguments
libref
A quoted string that contains the SAS libref or friendly library name associated with the library for which the list of defined SAS data sets is returned.
SAS Get Lib Refs(<named arguments>)
Description
Get a list of the currently defined SAS librefs on the current global SAS server connection.
Returns
Named Arguments
Friendly Names(0|1)
Optional, Boolean. If True, then for any libraries that have friendly names (metadata-defined libraries), the friendly name is returned rather than the 8-character libref.
SAS Get Log()
Description
Retrieve the SAS Log from the active global SAS server connection.
Returns
A quoted string.
SAS Get Output()
Description
Retrieve the listing output from the last submission of SAS code to the current global SAS server connection.
Returns
A quoted string.
SAS Get Results()
Description
Retrieve the results of the previous SAS Submit as a scriptable object, which allows significant flexibility in what to do with the results.
Returns
A SAS Results Scriptable object.
SAS Name("name")
SAS Name({list of names})
Description
Converts JMP variable names to SAS variable names by changing special characters and blanks to underscores and various other transformations to produce a valid SAS name.
Returns
A quoted string that contains one or more valid SAS names, separated by spaces.
Argument
"name"
A quoted string that represents a JMP variable name; or a list of quoted JMP variable names.
SAS Open For Var Names("path")
Description
Opens a SAS data set only to obtain the names of its variables, returning those names as a list of quoted strings.
Returns
A list of variable names in the file.
Argument
path
A quoted string that is a pathname of a SAS data set.
SAS Submit("sasCode", <named arguments>)
Description
Submit some SAS code to the active global SAS server connection.
Returns
1 if successful, 0 otherwise.
Arguments
sasCode
A quoted string that contains the SAS code to submit.
Async(0|1)
A Boolean. If True (1), the submit occurs asynchronously (in the background). Use the Get Submit Status() message on the SAS Server Scriptable Object to determine the status of the submit. The default value is False (0).
ConvertCustomFormats(0|1)
A Boolean. When SAS data sets generated by submitted SAS code are imported into JMP after the submit completes (see Open Output Datasets), the value of ConvertCustomFormats determines whether an attempt is made to convert any custom formats found on columns in the SAS data to JMP value labels. The default value is True (1).
DeclareMacros(var1, var2, ...)
JSL variable names. Provides a simple way to pass the values of JSL variables to SAS as macro variables. Each JSL variable specified should evaluate to a quoted string or numeric value. Fully qualified JSL variables names, only the variable name is sent to SAS. For example, namespace:variable_name becomes variable_name in SAS.
GetSASLog(<Boolean|OnError>, <JMPLog|Window>)
A Boolean. If no arguments are supplied, the SAS Log is retrieved and displayed in the location indicated in SAS Integration Preferences. The first argument to GetSASLog can be either a Boolean value or the keyword OnError. If a Boolean value is supplied, true means display the SAS Log, and false means not to display it. OnError instructs JMP to only show the SAS Log if an error occurred in the submit. The second argument to GetSASLog tells JMP where to display the SAS Log. If JMPLog is specified, the SAS Log is appended to the JMP Log. If Window is specified, the SAS Log is opened in a separate window.
GraphicsDevice(string) or GDevice(string)
A quoted string that specifies a value for the GDEVICE SAS option to be used for graphics generated by the submitted SAS code. The value must be a valid SAS graphics device. The default value is determined in Preferences.
Interactive(0|1)
JMP includes the QUIT statement in the generated wrapper code. Interactive PROCs work even if JMP is generating the ODS wrapper. On every SUBMIT, specify the argument that is part of an interactive sequence. Otherwise, QUIT will be generated in both the prologue-generated and epilogue-generated code.
NoOutputWindow
A Boolean. If True, the SAS Output window containing the listing output from the submission does not appear. The default value is False.
ODS(0|1)
If true, additional SAS code is submitted causing ODS results to be generated for the submitted SAS code. The default value is determined in Preferences.
ODSFormat(string)
A quoted string that determines the format of generated ODS results. Valid values are “HTML”, “RTF”, and “PDF”. The default value is determined in Preferences.
ODSGraphics(0|1)
If true, ODS statistical graphics are generated for the submitted SAS code. Setting ODSGraphics to true causes ODS to also be set to true. The default value is determined in Preferences.
ODSStyle(string)
A quoted string that specifies the ODS Style to use when generating ODS results. String must be a valid SAS Style. The default value is determined in Preferences.
ODSStyleSheet(path)
A quoted string that specifies a local CSS style sheet to use when formatting generated ODS results. Path must be a path to a CSS file valid for the client machine (the machine running JMP). The default value is determined in Preferences.
OnSubmitComplete(script)
A quoted string that specifies a JSL script that should be run when the submit completes. This is especially useful for asynchronous submits. If script is the name of a defined JSL function, that function is executed, with the SAS Server scriptable object passed as the first argument.
OpenODSResults(0|1)
If true, ODS results that are generated by the submitted SAS code (due to ODS being true) are automatically opened after the submit completes. The default value is True (1).
OpenOutputDatasets(<All|None|dataset1, dataset2, ...>)
JMP detects when submitted SAS code creates new SAS data sets. OpenOutputDatasets (which can be abbreviated OutData) determines what, if anything, is done with those data sets with the SAS Submit completes. If All is specified, all data sets generated by the SAS code are imported into JMP when the SAS Submit completes. If None is specified, none of the generated data sets are imported. If there are specific data sets known to be generated by the submitted SAS code that you want to be imported into JMP when the SAS submit completes, you can alternative provide their names, and only the requested data sets are imported. The default value is determined in Preferences.
Title(string)
A quoted string that specifies the window title to use for the window that displays ODS output from the submit.
SAS Submit File("filename", <named arguments>)
Description
Submit a SAS code file to the active global SAS server connection.
Returns
1 if successful; 0 otherwise.
Arguments
filename
A quoted string that contains the name of file containing SAS code to submit.
Named Arguments
Same as for SAS Submit.
