DRAFT help
Using JMP > Get Started with JMP > Manage Files and Open Windows > Search for Recently Opened Files on Windows
Publication date: 01/13/2026
On Windows, recently opened files appear in the Home Window. You can also search for recently opened files from any JMP window.
Select File > Quick Open or press Alt+Shift+O to open the Filter box and enter your search term. This option also lets you view the file’s path. Press Esc or click the x button to close the window after you enter a search term.
