DRAFT help
Publication date: 01/13/2026
Statistical Details for Attributes List Format
When the data table is an attributes list, it is converted to a distance matrix and then Multidimensional Scaling is applied. The distance matrix is calculated using Euclidean distance. For each pair of items define the distance between the items using the following formula:
Equation shown here
where k is the number of attributes. It is assumed that the measures are on the same scale.
