DRAFT help
Using JMP > Summarize Your Data > Summarize Columns > Summary Launch Window
Publication date: 01/13/2026
Statistics
Defines the summary statistics (such as mean, standard deviation, and median) for a numeric column in the source table. See Add Summary Statistics.
Group
Summarizes the statistics by group. See Use One or More Grouping Columns.
Subgroup
Summarizes the statistics by subgroup. See Create a Two-Way Table of Summary Statistics by Adding a Subgroup Variable.
Freq
Identifies a column whose values assign a frequency to each row.
Weight
Identifies a column whose values assign a weight to each row.
Note: Table scripts made from summaries with no Freq or Weight variables specified will include these variables and set them to None. When the source table for the summary has columns assigned to the Freq or Weight roles, those columns will be used instead.
