DRAFT help
Basic Analysis > Tabulate > Tabulate Platform Options
Publication date: 01/13/2026
The following options are available from the Tabulate red triangle menu:
Show Control Panel
Displays the control panel for further interaction.
Show Table
Displays the summarized data in tabular form.
Show Chart
Displays the summarized data in bar charts that mirrors the table of summary statistics. The simple bar chart enables visual comparison of the relative magnitude of the summary statistics. By default, all columns of bars share the same scale. You can have each column of bars use the scale determined separately from the data in each displayed column, by clearing the Uniform plot scale check box. You can specify a uniform custom scale using the Change Plot Scale button. The charts are either 0-based or centered on 0. If the data are all nonnegative, or all nonpositive, the charts baseline is at 0. Otherwise, the charts are centered on 0.
Show Shading
Displays gray shading boxes in the table when there are multiple rows.
Show Tooltip
Displays tips that appear when you hover over areas of the table.
Show Test Build Panel
Displays the control area that lets you create a test build using a random sample from the original table. This is particularly useful when you have large amounts of data. See Show Test Build Panel.
Make Into Data Table
Makes a data table from the report. There is one data table for each row table, because labels of different row tables might not be mapped to the same structure.
Data Table Options
Provides options to set prior to making a tabulation into a data table.
Full Path Column Name
Uses the fully qualified column names of grouping columns for the column name in the created data table.
Save Grouping as Tags
Adds Tags to the Data Table for each level of grouping variables in the created data table. See “Column Tags” in Using JMP.
Scroll Lock Row Headers
Locks the columns of row headers in the created data table. See “Lock Columns” in Using JMP.
Set Max Scroll Locked Columns
Sets the maximum of row header columns to lock in the created data table.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
For a description of the options in the Select Columns red triangle menu, see “Column Filter Menu” in Using JMP.
