DRAFT help
Using JMP > Summarize Your Data > Summarize Columns > Add a Statistics Column to an Existing Summary Table
Publication date: 01/13/2026
After you have created a summary table, you can add columns of descriptive summary statistics for any numeric column in the source table. To do so, from an existing summary table, click the upper red triangle in the data grid and select Add Statistics Column.
Example of Adding a Statistics Column to an Existing Table
Suppose that you have created a summary table, and you want to add more statistics to the existing summary table.
1. Select Help > Sample Data Folder and open Companies.jmp.
2. Select Tables > Summary.
3. Select Type and Size Co and click Group.
4. Click OK.
5. Click the red triangle in the Columns panel and select Add Statistics Column.
Figure 8.3 Creating a Summary Statistics Column from Within a Data TableĀ
A modified version of the Summary window appears.
6. Select the column that you want, click Statistics, and select the specific statistic that you want.
For this example, select profit/emp, click Statistics, and then select Mean.
7. Click OK.
Figure 8.4 Example of a Summary Table with a Summary Statistics ColumnĀ
The Mean(profit/emp) column is added to the existing summary table.
