DRAFT help
Using JMP > Save and Share Your Data > Create Journals > Append Reports to Journals
Publication date: 01/13/2026
To append other reports to a report that you already journaled, open the journal and select Edit > Journal. If an area of an analysis window is selected, Edit > Journal saves only the selected area instead of the entire window.
Notes:
The journal window has the same functions as the report window. You can click icons, click and drag, and right-click to access menus.
When a report is journaled, the journaled copy is no longer connected to the data table. To maintain that connection, save the report as a JMP report and insert a link to the report in the journal.
