DRAFT help
Publication date: 01/13/2026
Image shown hereBatch Selection Tab
The Batch Selection tab contains a Bayesian Optimization Batch Customizer section and a Current Batch section. The Bayesian Optimization Batch Customizer section is closed by default. This section enables you to explore different ways to generate new factor settings, and it contains the current candidate set. The Current Batch section lists the factor combinations that are selected for inclusion in the current batch, along with options for where to save them.
Candidate Set
Current Batch
