DRAFT help
Publication date: 01/13/2026
Comparison Functions
In the JMP Formula Editor, you can create a formula that compares the values of two arguments by using the comparison function. Each comparison relationship evaluates as true or false based on numeric magnitudes or character rankings. A true relationship evaluates as one, and false evaluates as zero.
Comparisons are useful when you include them in conditional expressions, but they can also stand alone as numeric expressions if neither term in the comparison is missing. A relational symbol’s arguments can be any two expressions. However, both arguments in a comparison function must be of the same data type. Also note the following information:
JMP displays an error if you use a single “=” in a conditional where “==” is expected.
The Formula Editor uses the International Utilities package when comparing character strings. This package contains different rankings for each international character set and takes diacritical marks into consideration.
You should not use comparison operators to specifically compare to a missing value. Instead, use the Is Missing function to detect a missing value.
For more information about syntax, see “Comparison Functions” in the JSL Syntax Reference.
Less than
Greater than
Less than or equal to
Greater than or equal to
Equal to
Not equal to
a<b<=c
b is greater than a and less than or equal to c
a<=b<c
b is greater than or equal to a and less than c
Is Missing
Returns a one (1) if the value of the argument for the current row is missing and a zero if the value is not missing.
