DRAFT help
Using JMP > Create Formulas in JMP > Edit Formulas > Correct Mistakes in Formulas
Publication date: 01/13/2026
If you make a mistake while entering a formula in the Formula Editor, press Ctrl+Z. This reverses the effect of the last (undoable) command.
You can also modify formulas with the following commands:
Click the delete button Image shown here on the Formula Editor keypad to remove the selected expression.
Use the cut, copy, and paste keyboard shortcut commands or right-click a highlighted part of the formula and select Cut, Copy, or Paste from the menu.
Drag portions of the formula to rearrange them.
