DRAFT help
Publication date: 01/13/2026
Create Excel Workbooks
You can save open data tables in a new or existing Excel workbook by using the Create Excel Workbook() function. The first example adds all open data tables without changing the worksheet names:
dt1 = Open( "$SAMPLE_DATA/Big Class Families.jmp" );
dt2 = Open( "$SAMPLE_DATA/NYC 311 Records.jmp" );
Create Excel Workbook( "C:\MyWorkbook1.xlsx" );
The following example creates MyWorkbook2.xlsx by combining the open Big Class Families.jmp and NYC 311 Reccords.jmp sample data tables.
// specify the data tables
tableList = {"Big Class Families", "NYC 311 Records"};
// specify the worksheets (optional)
sheetList = {"Families", "Records"};
Create Excel Workbook( "C:\MyWorkbook2.xlsx", tableList, sheetList );
Use data table references to create the workbook.
	"C:\MyWorkbook3.xlsx",
	{dt1, dt2}, // data table references
Create Excel Workbook() also accepts a mix of data table references and data table names in the list. For example, {dt1, dt2} above can also be expressed as {dt1, "NYC 311 Records"}.
Notes:
The saved file is an .xlsx file; the .xls format is not supported.
The JMP data tables must conform to the maximum Excel limit of 1 million rows and 16,535 columns, or the data will be truncated in Excel.
Data table references or data table names must always be in a list, even if the list has only one item.
