DRAFT help
Using JMP > JMP Reports > Customize Hover Labels in JMP Graphs
Publication date: 01/13/2026
When you hover over a visual element in a JMP graph, you usually see a basic description of the data point in a hover label. Customize what appears in the hover label in any of these ways:
Add interactive graphs or images with graphlets.
See Add Graphs or Images to Hover Labels.
Add formatted text with textlets.
See Add Text to Hover Labels in JMP Graphs.
Add, remove, or update names and values by using gridlets.
See Update Names and Values in Hover Labels.
Learn more about using the Hover Label Editor.
See Edit Hover Labels in JMP Graphs.
Add images from data tables.
See Add Images from JMP Data Tables to Hover Labels.
Pin hover labels on graphs.
See Pin Hover Labels in JMP Graphs.
Format hover labels and access additional options.
See Right-Click Options for Hover Labels.
Figure 9.54 Examples of Graphs, Text, Names, and Values in Hover LabelsĀ
