DRAFT help
Publication date: 01/13/2026
Deauthorize User
The Deauthorize option in the Help menu enables you to log out of JMP and then sign in with a different account. This option removes the authorization for the current device or user.
1. Select Help > Deauthorize.
2. When prompted, confirm the deauthorization.
3. The next time you start JMP on this machine, you are prompted to authorize again. Enter your email address to complete the process.
