DRAFT help
Welcome to JMP > Learn about JMP > Documentation PDF Add-in
Publication date: 01/13/2026
You can download and install the JMP documentation add-in. The documentation add-in contains an individual PDF file of each document in the JMP library and the JMP Documentation Library file. The JMP Documentation Library file is one PDF file that contains all the individual book PDF files, which lets you search all individual books from a single PDF file, similar to the JMP Online Help.
When installed, the documentation add-in adds the Documentation PDFs option to the Help menu and installs the PDF files on your machine. This enables you to access the documentation locally by selecting Help > Documentation PDFs. Download the available documentation add-ins from https://www.jmp.com/doc-addin.
The following table describes the purpose and content of each document in the documentation add-in.
Document Title
Document Content
Provides one PDF file that includes the other individual JMP documentation book PDF files.
Discovering JMP
Provides a starting point if you are not familiar with JMP. The book introduces you to JMP and gets you started creating and analyzing data, and sharing your results.
Using JMP
Explains JMP data tables and how to perform basic operations. It covers general concepts and features that span all of JMP, including importing data, modifying column properties, sorting data, and using workflows.
Basic Analysis
Describes the following basic analyses that you can do from the Analyze menu:
Distribution
Fit Y by X
Tabulate
Text Explorer
It covers how to perform bivariate, one-way ANOVA, and contingency analyses using the Analyze > Fit Y by X platform. The book also addresses how to approximate sampling distributions using bootstrapping and how to perform parametric resampling with the Simulate platform.
Essential Graphing
Describes the following Graph menu platforms:
Graph Builder
Scatterplot 3D
Contour Plot
Bubble Plot
Parallel Plot
Cell Plot
Scatterplot Matrix
Ternary Plot
Treemap
Chart
Overlay Plot
The book also explains how to create background and custom maps.
Profilers
Explains how to use interactive profiling tools, which enable you to view cross-sections of any response surface. It explains all profilers listed in the Graph menu. Analyzing noise factors is included along with running simulations using random inputs.
Design of Experiments Guide
Describes how to design experiments and determine appropriate sample sizes and covers all topics in the DOE menu.
Fitting Linear Models
Describes the following personalities, all available within the Analyze > Fit Model platform:
Standard Least Squares
Stepwise
Generalized Regression
Mixed Model
Generalized Linear Mixed Model
MANOVA
Loglinear Variance
Nominal Logistic
Ordinal Logistic
Generalized Linear Model
Causal Treatment
Describes the following platforms in the Analyze > Predictive Modeling menu:
Neural
Partition
Bootstrap Forest
Boosted Tree
K Nearest Neighbors
Naive Bayes
Support Vector Machines
Model Comparison
Model Screening
Make Validation Column
Formula Depot
Describes the following platforms in the Analyze > Specialized Modeling menu:
Fit Curve
Nonlinear
Functional Data Explorer
Gaussian Process
Bayesian Optimization
Time Series
Time Series Forecast
Matched Pairs
Describes the following Analyze > Screening menu platforms:
Explore Outliers
Explore Missing Values
Explore Patterns
Response Screening
Predictor Screening
Association Analysis
Process History Explorer
Multivariate Methods
Covers how to analyze several variables simultaneously.
Describes the following Analyze > Multivariate Methods menu platforms:
Multivariate
Principal Components
Discriminant
Partial Least Squares
Multiple Correspondence Analysis
Structural Equation Models
Factor Analysis
Multidimensional Scaling
Multivariate Embedding
Item Analysis
Describes the following Analyze > Clustering menu platforms:
Hierarchical Cluster
K Means Cluster
Normal Mixtures
Latent Class Analysis
Cluster Variables
Quality and Process Methods
Covers statistical tools for evaluating and improving processes.
Describes the following Analyze > Quality and Process menu platforms:
Control Chart Builder and individual control charts
Measurement Systems Analysis (EMP and Type 1 Gauge)
Variability / Attribute Gauge Charts
Process Screening
Process Capability
Model Driven Multivariate Control Chart
Legacy Control Charts
Pareto Plot
Diagram
Manage Limits
OC Curves
Covers evaluating and improving reliability in a product or system and analyzing survival data for people and products.
Describes the following Analyze > Reliability and Survival menu platforms:
Life Distribution
Reliability Forecast
Fit Life by X
Fit Parametric Survival
Cumulative Damage
Fatigue Model
Repeated Measures Degradation
Destructive Degradation
Recurrence Analysis
Reliability Growth
Reliability Block Diagram
Repairable Systems Simulation
Survival
Degradation
Fit Proportional Hazards
Consumer Research
Explains how to study consumer preferences and create better products and services.
Describes the following Analyze > Consumer Research menu platforms:
Categorical
Choice
MaxDiff
Uplift
Multiple Factor Analysis
Life Sciences
Illustrates how to analyze your genetic data to simulate a breeding program to predict the optimum genetic crosses to make.
Describes the following Analyze > Life Sciences menu platforms:
Marker Statistics
Marker Simulation
Marker Relatedness
Marker Admixture
Marker Imputation
Normalization
Distance Matrix
Scripting Guide
Defines the powerful JMP Scripting Language (JSL). Covers a variety of topics, such as writing and debugging scripts, manipulating data tables, constructing display boxes, and creating JMP applications.
JSL Syntax Reference
Provides an overview of the JSL function arguments and messages. Includes syntax, examples, and notes for JSL commands.
Keyboard Shortcuts
Explains how to use your keyboard to quickly navigate JMP and complete tasks. Includes commands and the corresponding keystrokes for both Windows and Apple macOS.
Menu Descriptions
Covers JMP menu options for both Windows and Apple macOS.
