DRAFT help
Publication date: 01/13/2026
Estimates of Relative Efficiency
Notation
X is the model matrix
p is the number of terms, including the intercept, in the model
Equation shown here is the relative prediction variance at the point Equation shown here. See “Relative Prediction Variance”.
Relative Efficiencies
The relative efficiency of the reference design (Ref) to the comparison design (Comp) is given by the following expressions:
D Efficiency
EffRef / EffComp, where Eff for each design is given as follows:
Equation shown here
G Efficiency
EffComp / EffRef, where Eff for each design is given as follows:
Equation shown here
Here, D denotes the design region.
Note: G-Efficiency is calculated using Monte Carlo sampling of the design space. The reported value is based on the larger of Equation shown here or the prediction variance from the Monte Carlo sampling. Therefore, calculations for the same design might vary slightly.
A Efficiency
Equation shown here
I Efficiency
Equation shown here
For more information about the calculation, see Section 4.3.5 in Goos and Jones (2011).
