DRAFT help
Publication date: 01/13/2026
Estimates of Relative Standard Error
The Relative Std Error of Estimates report gives the ratio of the standard deviation of a parameter’s estimate to the error standard deviation. These values indicate how large the standard errors of the model’s parameter estimates are, relative to the error standard deviation. For the ith parameter estimate, the Relative Std Error of Estimate is defined as follows:
Equation shown here
where:
X is the model matrix defined in “The Alias Matrix”, and
Equation shown here is the ith diagonal entry of Equation shown here.
