DRAFT help
Using JMP > Workflow Builder > Additional Examples of the Workflow Builder > Example of Creating a Workflow with a Step Setting
Publication date: 01/13/2026
In this example, add steps to a workflow from the Enhanced Log.
1. Select File > New > Workflow.
2. Click Image shown here to start recording your actions.
3. Select Help > Sample Data Folder and open Iris.jmp.
4. From the Workflow Builder red triangle select Add Custom Step.
5. Click the gray triangle next to Step Settings.
6. Click Custom Image shown here in the Workflow Steps section.
7. In the Step Code section of the Step Settings panel type Oneway(Y(:Petal width), X(:Species)) and click away from the Code window.
8. Click Image shown here to stop recording.
9. Click Image shown here to reset.
This closes any open windows and resets the workflow to the start.
10. Click Image shown here to test the workflow.
Adding a step from the Step Settings is an alternative to recording, adding from the JMP Log History, or using the platform Save Script > to Workflow option. It also enables you to add JSL code for complex actions that are not recorded by the Workflow Builder.
