DRAFT help
Publication date: 01/13/2026
Get Started with JMP
When you first start JMP, you see the Quick Start, which helps new users begin to use JMP. To turn off the Quick Start, clear the Show at startup check box. To view it again, select Help > Quick Start. Or, you can turn Quick Start off by using the File > Preferences window.
