DRAFT help
Using JMP > Import Your Data > Import Data from Google Sheets
Publication date: 01/13/2026
A Google Sheet is a spreadsheet that is saved in your Google account. This enables you to continue to edit the spreadsheet and to share it with others.
You can import data from a Google spreadsheet by logging in to your Google account, copying the URL for the spreadsheet, and specifying how the data are structured. For example, you must know which row the data begin on if there are column headers.
To import data from a Google spreadsheet
1. Log in to https://sheets.google.com and open the spreadsheet.
2. Copy the URL in the browser’s address bar.
3. In JMP, select File > Internet Open > Google Sheets.
4. Enter your Google account name (@gmail.com is unnecessary).
5. Paste the URL in the Spreadsheet URL or ID field.
6. Click Import.
The data are imported into a JMP data table.
If you are importing data with the specified Google account for the first time, you are prompted to give JMP access to your Google account.
7. Click Allow.
