DRAFT help
Essential Graphing > Bubble Plots > Interact with the Bubble Plot
Publication date: 01/13/2026
Use the Bubble Plot platform in static or dynamic mode:
Static mode, where the bubbles are fixed and do not animate over time (no Time variable is specified). See Example of a Static Bubble Plot.
Dynamic mode, where the bubbles are animated over time (a Time variable is specified). See Example of a Dynamic Bubble Plot.
You interact with both static and dynamic bubble plots in different ways.
Note: If all of the rows that are used in constructing a bubble plot shape are hidden and not excluded, the corresponding bubble plot shape is not shown in the bubble plot. If rows are excluded in the data table, the bubble plot is constructed without the excluded rows.
