DRAFT help
Using JMP > JMP Technical Details > JMP Features That Support Multithreading
Publication date: 01/13/2026
Some features in JMP are coded to take advantage of multiple central processing units (CPUs) on a machine, allowing these features to run significantly faster. This process is called multithreading.
The following features support multithreading:
Image shown here Boosted Trees
Image shown here Bootstrap Forest
Choice
Image shown here Covering Arrays
Capability Analysis in Distribution
Explore Outliers
Explore Patterns
Factor Analysis
Fit Life by X
Fit Model: Parametric Survival, Image shown here Mixed Model, Image shown here Generalized Regression, and Image shown here Response Screening
Functional Data Explorer
Gaussian (Image shown here Fast GASP and the use of Categorical variables are in JMP Pro only.)
Image shown here K Nearest Neighbors
Latent Class Analysis
Life Distribution
Multivariate
Neural (Image shown here Some features are in JMP Pro only.)
Nominal Logistic
Nonlinear and Nonlinear Curve
Normal Mixtures in Cluster Analysis
Partial Least Squares (Image shown here Some features are in JMP Pro only.)
Partition
Predictor Screening
Principal Components
Process Screening
Profiler (Does not apply to Profilers launched from within other platforms.)
Reliability Forecast
Image shown here Repairable Systems Simulation
Response Screening
Image shown here Sparse Principal Components
Image shown here Structural Equation Models
Image shown here Support Vector Machines
SVD Imputation in the Missing Values Screening
Text Explorer (Image shown here Some features are in JMP Pro only.)
Time Series Forecast
Image shown here Uplift
Variable Clustering
