DRAFT help
Publication date: 01/13/2026
Learn about JSL
In addition to the Scripting Guide and JSL Syntax Reference, you can get assistance with JSL scripting by using the Scripting Index (Help > Scripting Index). Use the Scripting Index to search for information about JSL functions, objects, and display boxes. You can edit and run example scripts and get help on the commands.
An online version of the Scripting Index is available at https://jsl.jmp.com.
