DRAFT help
Fitting Linear Models
Publication date: 01/13/2026
Model Specification
Specify Linear Models
The Fit Model platform enables you to specify a variety of complex models using different fitting techniques or personalities. This chapter focuses on elements that are common to most personalities.
Fit Model personalities enable you to fit the following types of models:
Simple and multiple linear regression
Analysis of variance and covariance
Random effect, nested effect, mixed effect, repeated measures, and split plot models
Nominal and ordinal logistic regression
Multivariate analysis of variance (MANOVA)
Canonical correlation and discriminant analysis
Loglinear variance (to model the mean and the variance)
Generalized linear models (GLM)
Parametric survival and proportional hazards
Response screening, for studying a large number of responses
Image shown hereIn JMP Pro, you can also fit the following models:
Generalized regression models including the elastic net, lasso, and ridge regression
Mixed models with a range of covariance structures
Generalized linear mixed models (GLMM)
Partial least squares
Causal treatment models
Contents
Overview of the Fit Model Platform
Example of a Regression Analysis Using Fit Model
Launch the Fit Model Platform
Elements in the Fit Model Launch Window
Construct Model Effects
Fitting Personalities
Model Specification Options
Informative Missing
Validity Checks
Model Specification Templates
Simple Linear Regression
Polynomial in X to Degree k
Polynomial in X and Z to Degree k
Multiple Linear Regression
One-Way Analysis of Variance
Two-Way Analysis of Variance
Two-Way Analysis of Variance with Interaction
Three-Way Full Factorial
Analysis of Covariance, Equal Slopes
Analysis of Covariance, Unequal Slopes
Two-Factor Nested Random Effects Model
Three-Factor Fully Nested Random Effects Model
Simple Split Plot or Repeated Measures Model
Two-Factor Response Surface Model
Knotted Spline Effect
