DRAFT help
Design of Experiments Guide > Compare Designs > Overview of the Compare Designs Platform
Publication date: 01/13/2026
The Compare Designs platform enables you to easily compare up to four designs to a reference design. The Compare Designs platform is an extension of the Evaluate Design platform. To compare the performance of designs relative to one another, select a reference design that is treated as the base design. You can specify effects in the Model section, and effects of interest in the Alias Terms section.
The Design Evaluation report shows diagnostic results and plots for the following metrics and analyses:
Power analysis
Prediction variance
Fraction of design space
Relative estimation efficiency
Alias matrix diagnostics
Correlations among effects (including confounding)
Relative efficiency measures for the overall designs
