DRAFT help
Using JMP > Workflow Builder > Overview of the Workflow Builder
Publication date: 01/13/2026
The Workflow Builder is a utility that extends the actions that are recorded in the Enhanced Log to save JMP steps in a package for reuse. You can interactively record steps, rearrange steps, add steps from a log, or add JSL code to build a workflow. For more information about the Enhanced Log, see “Enhanced Log in JMP” in the Scripting Guide.
Caution: Most, but not all, JMP actions are recorded in the Enhanced Log. Actions that are not recorded in the Enhanced Log are not available for recording with the Workflow Builder.
