DRAFT help
Using JMP > Reference for JMP Functions in Formulas > Parametric Model Functions
Publication date: 01/13/2026
In the JMP Formula Editor, this category is a shortcut to create three parametric models that are linear functions of a set of window-selected columns.
Linear Model, Interactions Model, Full Quadratic Model
Selecting each of these options opens a column selection box that lets you select one or more columns to be included in the model. The function then creates and populates the chosen model.
