DRAFT help
Using JMP > JMP Preferences > Preferences for Updating JMP
Publication date: 01/13/2026
The JMP Update preferences show you what version of JMP you currently have, the last time JMP was updated, and whether and how often JMP automatically checks for updates.
Figure 15.32 JMP Updates Preferences
Table 15.32 Preferences on the JMP Updates Page
Preference
Description
Check for Updates
Select this option to have JMP automatically check for updates.
If this option is selected, specify how often the check is performed: Daily, Weekly, or Monthly.
Current Version
Shows what version of JMP you are currently running.
Last Check
Shows the last time that you checked for an update.
Check Now
Select this option to perform an update check immediately.
