DRAFT help
Discovering JMP > Save and Share Your Work > Recreate JMP Steps in a Workflow
Publication date: 01/13/2026
If you find yourself repeating the same steps in JMP, use the Workflow Builder. The Workflow Builder is a JMP utility to capture, build, manage, and share data preparation and analysis workflows.
Here are some situations where you might use Workflow Builder:
If you are repeating steps in JMP, like preparing data or making graphs
If you need to re-run a sequence of steps with new data
If you want to share a workflow in JMP with a colleague
If you need a complete log of an analysis to meet an industry requirement
