DRAFT help
Publication date: 01/13/2026
References
The following sources are referenced in Predictive and Specialized Modeling.
Agrawal, R., and Srikant, R. (1994). “Fast Algorithms for Mining Association Rules.” In Proceedings of the 20th VLDB Conference. Santiago, Chile: IBM Almaden Research Center.
Baek, S. J., Park, A., Ahn, Y. J. and Choo, J. (2015). “Baseline Correction Using Asymmetrically Reweighted Penalized Least Squares Smoothing.” Analyst 140(1):250–257.
Bates, D. M., and Watts, D. G. (1988). Nonlinear Regression Analysis and Its Applications. New York: John Wiley & Sons.
Benford, F. (1938). “The Law of Anomalous Numbers.” Proceedings of the American Philosophical Society 78(4):551–572.
Benjamini, Y., and Hochberg, Y. (1995). “Controlling the False Discovery Rate: A Practical and Powerful Approach to Multiple Testing.” Journal of the Royal Statistical Society, Series B 57:289–300.
Benjamini, Y., Yekutieli, D., Edwards, D., Shaffer, J. P., Tamhane, A. C., Westfall, P. H., and Holland, B. (2005). “False Discovery Rate: Adjusted Multiple Confidence Intervals for Selected Parameters.” Journal of the American Statistical Association 100:71–93.
Bloomfield, P. (2004). Fourier Analysis of Times Series: An Introduction. New York: John Wiley & Sons.
Box, G. E. P., Jenkins, G. M., and Reinsel, G. C. (1994). Time Series Analysis: Forecasting and Control. 3rd ed. Englewood Cliffs, NJ: Prentice-Hall.
Candes, E. J., Li, X., Ma, Y., and Wright, J. (2009). “Robust Principal Component Analysis?” Journal of the ACM 58:1–37.
Cleveland, W. S. (1994). Visualizing Data. Summit, NJ: Hobart Press.
Conover, W. J. (1999). Practical Nonparametric Statistics. 3rd ed. New York: John Wiley & Sons.
Cureton, E. E. (1967). “The Normal Approximation to the Signed-Rank Sampling Distribution When Zero Differences Are Present.” Journal of the American Statistical Association 62:1068–1069.
Donoho, D. L. (1995). “De-noising by Soft-Thresholding.” IEEE Transactions on Information Theory 41:613–627.
Du, P., Kibbe, W. A., and Lin, S. M. (2006). “Improved Peak Detection in Mass Spectrum by Incorporating Continuous Wavelet Transform-Based Pattern Matching.” Bioinformatics 22(17):2059–2065.
Efron, B. (1981). “Nonparametric Standard Errors and Confidence Intervals.” The Canadian Journal of Statistics 9:139–172.
Geladi, P., MacDougall, D., and Martens, H. (1985). “Linearization and Scatter-Correction for Near-Infrared Reflectance Spectra of Meat.” Applied Spectroscopy 39:491–500.
Hahsler, M. (2015). “A Probabilistic Comparison of Commonly Used Interest Measures for Association Rules.”GitHub. https://mhahsler.github.io/arules/docs/measures.
Haldane, J. B. (1956). “The Estimation and Significance of the Logarithm of a Ratio of Frequencies.” Annals of Human Genetics 20:309–311.
Hand, D. J., Mannila, H., and Smyth, P. (2001). Principles of Data Mining. Cambridge, MA: MIT Press.
Hastie, T. J., Tibshirani, R. J., and Friedman, J. H. (2009). The Elements of Statistical Learning: Data Mining, Inference, and Prediction. 2nd ed. New York: Springer-Verlag.
Hawkins, D. M., and Kass, G. V. (1982). “Automatic Interaction Detection.” In Topics in Applied Multivariate Analysis, edited by D. M. Hawkins, 267–300. Cambridge: Cambridge University Press.
Hirschberg, J., and Lye, J. (2010). “A Geometric Comparison of the Delta and Fieller Confidence Intervals.” The American Statistician 64(3):234–241.
Hoffelder, T. (2019). “Equivalence Analyses of Dissolution Profiles with the Mahalanobis Distance.” Biometrical Journal 61(5):1120–1137.
Huber, P. J., and Ronchetti, E. M. (2009). Robust Statistics. 2nd ed. New York: John Wiley & Sons.
Hyndman, R. J., Koehler, A. B., Ord, J. K., and Snyder, R. D. (2008). Forecasting with Exponential Smoothing: The State Space Approach. Berlin: Springer-Verlag.
Jolliffe, I. T. (2002). Principal Component Analysis. New York: Springer-Verlag.
Kass, G. V. (1980). “An Exploratory Technique for Investigating Large Quantities of Categorical Data.” Journal of the Royal Statistical Society, Series C 29:119–127.
Lee, M., Shen, H., Huang, J. Z., and Marron, J. S. (2010). “Biclustering via Sparse Singular Value Decomposition.” Biometrics 66(4):1087–1095.
Lehman, E. L. (2006). Nonparametrics: Statistical Methods Based on Ranks. 2nd ed. New York: Springer.
Lin, Z., Chen, M., and Ma, Y. (2013). “The Augmented Lagrange Multiplier Method for Exact Recovery of Corrupted Low-Rank Matrices.” arXiv preprint arXiv:1009.5055.
Mason, R. L., and Young, J. C. (2002). Multivariate Statistical Process Control with Industrial Applications. Philadelphia: SIAM.
McCullagh, P., and Nelder, J. A. (1989). Generalized Linear Models. 2nd ed. London: Chapman & Hall.
Nagelkerke, N. J. D. (1991). “A Note on a General Definition of the Coefficient of Determination.” Biometrika 78:691–692.
Nason, G. P., ed. (2008). Wavelet Methods in Statistics with R. New York: Springer.
Nelder, J. A., and Wedderburn, R. W. M. (1972). “Generalized Linear Models.” Journal of the Royal Statistical Society, Series A 135:370–384.
Paixão, P., Gouveia, L. F., Silva, N., and Morais, J. A. (2017). “Evaluation of Dissolution Profile Similarity–Comparison between the f2, the Multivariate Statistical Distance and the f2 Bootstrapping Methods.” European Journal of Pharmaceutics and Biopharmaceutics 112:67–74.
Parker, R. J. (2015). Efficient Computational Methods for Large Spatial Data. Ph.D. diss., Department of Statistics, North Carolina State University. http://www.lib.ncsu.edu/resolver/1840.16/10572.
Platt, J. (1998). Sequential Minimal Optimization: A Fast Algorithm for Training Support Vector Machines. Technical Report MST-TR-98-14, Microsoft Research.
Qian, P. Z., Huaiquing, W., and Wu, C. F. (2012). “Gaussian Process Models for Computer Experiments with Qualitative and Quantitative Factors.” Technometrics 50:383–396.
Ramsay, J. O., and Silverman, B. W. (2005). Functional Data Analysis. 2nd ed. New York: Springer.
Ratkowsky, D. A. (1990). Handbook of Nonlinear Regression Models. New York: Marcel Dekker.
Ryan, C. G., Clayton, E., Griffin, W. L., Sie, S. H., and Cousens, D. R. (1988). “SNIP, a Statistics-Sensitive Background Treatment for the Quantitative Analysis of PIXE Spectra in Geoscience Applications.” Nuclear Instruments and Methods in Physics Research Section B: Beam Interactions with Materials and Atoms 34(3):396–402.
Sall, J. (2002). Monte Carlo Calibration of Distributions of Partition Statistics. Technical Report, Cary, NC: SAS Institute Inc. https://www.jmp.com/content/dam/jmp/documents/en/white-papers/montecarlocal.pdf.
Santer, T., Williams, B., and Notz, W. (2003). The Design and Analysis of Computer Experiments. New York: Springer-Verlag.
SAS Institute Inc. (2025). SAS/ETS User’s Guide. Cary, NC: SAS Institute Inc. https://go.documentation.sas.com/api/collections/pgmsascdc/v_070/docsets/etsug/content/etsug.pdf.
Savitzky, A., and Golay, M. J. (1964). “Smoothing and Differentiation of Data by Simplified Least Squares Procedures.” Analytical Chemistry 36:1627–1639.
Schäfer, J., and Strimmer, K. (2005). “A Shrinkage Approach to Large-Scale Covariance Matrix Estimation and Implications for Functional Genomics.” Statistical Applications in Genetics and Molecular Biology 4, Article 32.
Schuirmann, D. J. (1987). “A Comparison of the Two One-Sided Tests Procedure and the Power Approach for Assessing the Equivalence of Average Bioavailability.” Journal of Pharmacokinetics and Biopharmaceutics 15:657–680.
Shiskin, J., Young, A. H., and Musgrave, J. C. (1967). The X-11 Variant of the Census Method II Seasonal Adjustment Program. Technical Report 15, US Department of Commerce, Bureau of the Census.
Shmueli, G., Patel, N. R., and Bruce, P. C. (2010). Data Mining for Business Intelligence: Concepts, Techniques, and Applications in Microsoft Office Excel with XLMiner. 2nd ed. Hoboken, NJ: John Wiley & Sons.
Shmueli, G., Bruce, P. C., Stephens, M. L., and Patel, N. R. (2017). Data Mining for Business Intelligence: Concepts, Techniques, and Applications with JMP Pro. Hoboken, NJ: John Wiley & Sons.
Smyth, G. K. (2004). “Linear Models and Empirical Bayes Methods for Assessing Differential Expression in Microarray Experiments.” Statistical Applications in Genetics and Molecular Biology 3(1):1–25.
Tippey, K. G., and Longnecker, M. T. (2016). “An Ad Hoc Method for Computing Pseudo-Effect Size of Mixed Models.” In Proceedings of the South Central SAS Users Group Forum. Cary, NC: SAS Institute Inc.
Tsong, Y., Hammerstrom, T., Sathe, P., and Shah, V. P. (1996). “Statistical Assessment of Mean Differences between Two Dissolution Data Sets.” Drug Information Journal 30(4):1105–1112.
Westfall, P. H., Tobias, R. D., and Wolfinger, R. D. (2011). Multiple Comparisons and Multiple Tests Using SAS. 2nd ed. Cary, NC: SAS Institute Inc.
Zhang, J. H., Chung, T. D., and Oldenburg, K. R. (1999). “A Simple Statistical Parameter for Use in Evaluation and Validation of High Throughput Screening Assays.” Journal of Biomolecular Screening 4(2):67–73.
