DRAFT help
Publication date: 01/13/2026
Relative Estimation Efficiency
In the Compare Designs report, the Relative Estimation Efficiency section compares designs in terms of the standard errors of parameter estimates for parameters in the assumed model. The standard errors control the length of confidence intervals for the parameter estimates. This section provides tables of the efficiency ratio and the relative standard error estimates.
For a given term, the estimation efficiency of the reference design relative to the comparison design is the relative standard error of the term for the comparison design divided by the relative standard error of the term for the reference design. A value less than one indicates that the reference design is not as efficient as the comparison design. A value greater than one indicates that it is more efficient.
Figure 17.16 Relative Estimation Efficiency Table
The relative estimation efficiency values are colored according to a color gradient shown under the table of relative estimation efficiency values. You can control the color legend using the options in the Relative Estimation Efficiency red triangle menu. See Color Legend.
The Relative Estimation Efficiency section also includes a Relative Std Error of Estimates report. This report lists the ratio of the standard deviation of a parameter’s estimate to the error standard deviation. These values indicate how large the standard errors of the model’s parameter estimates are, relative to the error standard deviation.
