DRAFT help
Design of Experiments Guide > Sample Size Explorers > Remembered Settings in the Sample Size Explorers
Publication date: 01/13/2026
The Remembered Settings report provides a table of saved settings enabling you to compare study scenarios. Each time you click the Remember Settings button, a new row is added to the table. Use the radio buttons to select a row in the table to reset the explorer to those settings.
Note: In some explorers, this report is called the Saved Settings report.
The Remembered Settings red triangle contains the following options:
Differences Report
(Not available in all explorers.) Shows or hides a report of pairwise differences in power between the settings listed in the Remembered Settings table.
Remove Selected
Removes the selected rows from the Remembered Settings table.
Remove All
Removes the Remembered Settings section of the report.
Tip: To make a table that contains all Remembered Settings, right-click in the table and select Make Into Data Table.
