DRAFT help
Discovering JMP > Save and Share Your Work > Save and Run Scripts
Publication date: 01/13/2026
Most platform actions that you perform in JMP can be saved as a script by using JMP Scripting Language (JSL). You can use a script to reproduce your actions or results at any time.
This section contains the following information:
Example of Saving and Running a Script
About Scripts and JSL
