DRAFT help
Discovering JMP > Save and Share Your Work > Save Reports as Interactive HTML
Publication date: 01/13/2026
Interactive HTML enables you to share JMP reports that contain dynamic graphs so that even non-JMP users can explore the data. JMP reports are saved as an interactive web page that you can share with others (for example, on a shared network drive, by email, or on a website). Users then explore the data as they would in JMP.
