DRAFT help
Publication date: 01/13/2026
Step Settings
Use the Step Settings section to edit workflow steps or to add advanced steps to the workflow. Double-click a step to open or close the Step Settings. The Step Settings includes a time stamp for the last time that the steps were updated. When making changes, a status indicator shows that the workflow is Updating or Updated.
Step Name
Enables you to edit step names.
Notes
Enables you to add notes to a step. This adds a note icon to the step. Use to annotate your workflow.
Add action
Enables you to add an action to the workflow. Click outside of the Step Settings to add the action to the workflow.
Show Message
Adds a pop-up message to the workflow.
Subset
Opens a Subset section to select a random subset of all tables that are opened in a specific step.
Set Random Seed
Opens a Set Random Seed section to set a random seed for a specific step. Use to generate the same results with each run of the workflow. Many modeling techniques use random starting points.
Hide Tables
Adds a hide tables step action. After the step runs, any tables that are created during that step are marked as invisible. Use this to hide intermediate tables that do not need to be seen but cannot be closed because reports or other tables depend on them.
Custom
Use to add a custom action to a step in your workflow. Use any valid JSL statement or function.
Step Code
Contains the JSL code for each step. Enables you to view and edit the JSL code.
Step Action Timeline
Use the Step Action Timeline to customize your workflow. For example, use to add wait steps.
