DRAFT help
Publication date: 01/13/2026
The JMP Starter Window
The JMP Starter window is a good place to begin if you are not familiar with JMP or data analysis. Options are categorized and described, and you launch them by clicking a button. The JMP Starter window covers many of the options found in the Analyze, Graph, Tables, and File menus. The window also lists JMP Pro features and platforms.
To open the JMP Starter window, select View (Window on Apple macOS) > JMP Starter.
To display the JMP Starter automatically when you open JMP on Windows, select File > Preferences > General, and then select JMP Starter from the Initial JMP Window list. On Apple macOS, select JMP > Preferences > General > Initial JMP Starter Window.
