DRAFT help
Publication date: 01/13/2026
Use Basic Features in the JMP Formula Editor
The following example uses the Big Class.jmp sample data table to walk you through using the basic features of the Formula Editor. Big Class.jmp has a column called weight. Suppose that you want to add a new column that computes standardized weight values.
To create this column by using a formula to obtain its values, follow these steps:
2. Select Cols > New Columns.
3. Type the new name, standard weight, in the box beside Column Name.
4. Select Formula from the Column Properties menu.
5. Click the empty formula element in the formula editing area to select it.
When you create a formula and Show Boxing is checked, the selected portion of the formula is outlined with a thin blue line. See Hide and Show Outlines in Formulas. All terms within the smallest nesting box relative to the place that you clicked become selected, and the subsequent action applies to those combined elements.
Next, enter the formula that standardizes the weight values.
1. While the initial missing term is selected, click weight in the Columns list.
2. Click the minus button Image shown here in the Formula Editor keypad.
3. Click weight again.
4. Click the Functions list, and select Statistical.
5. Select Col Mean from the Statistical list.
6. Select the entire expression.
The blue box should now enclose the entire formula.
7. Click the division button Image shown here in the keypad.
The result gives a selected missing denominator for the entire expression.
8. Click weight again from the column selector list.
It becomes selected in the denominator.
9. Select Col Std Dev from the Statistical list.
Figure 7.20 Building a Formula
Building a Formula
10. Close the Formula Editor by clicking OK.
11. Close the Column Info window by clicking OK.
In the data table, the new standard weight column fills with values. When a weight value changes, the calculated standard weight value automatically recalculates.
