Scripting Guide > JSL Building Blocks > Iterate Functions > Break and Continue Functions
발행일 : 03/10/2025
The Break() and Continue() functions give you more control over looping. Break() immediately stops the loop and proceeds to the next expression that follows the loop. Continue() is a gentler form of Break(). It immediately stops the current iteration of the loop and continues with the next iteration of the loop.
Break
Break() is typically used inside a conditional expression. For example:
For( i = 1, i <= 5, i++,
	If( i == 3, Break() );
	Print( "i=" || Char( i ) );
results in:
"i=1"
"i=2"
The script works like this:
For(
Begins the For() loop.
i = 1,
Sets i to 1.
i <= 5,
As long as i is less than or equal to 5, continues evaluating the loop.
i++,
Increments i by 1. Note that this step is done after the If loop is evaluated.
If(
Begins the If() loop.
i == 3, Break()
If i is equal to 3, breaks the loop.
Ends the loop.
Print(
When i is not equal to 3, opens the Print() loop.
"i="
Prints the string "i=" to the log.
Places "i=" on the same line as the value that follows.
Char(i));
Prints the value of i to the log.
The For() loop then repeats until the value of i is less than or equal to 5, breaking when i equals 3, and breaking and printing only when i is less than 3.
Ends the loop.
Note that when the If() and Break() expressions follow Print(), the script prints the values of i from 1 to 3, because the loop breaks after "i=3" is printed.
"i=1"
"i=2"
"i=3"
Continue
As with Break(), Continue() is typically used inside a conditional expression. For example:
	If( i < 3, Continue() );
results in:
"i=3"
"i=4"
"i=5"
For(
i = 1,
Sets i to 1.
i <= 5,
Evaluates 1 as less than or equal to 5.
i++,
If(
i < 3, Continue()
Evaluates i as 1 and continues as long as i is less than 3.
Ends the If() loop.
Print(
When i is no longer less than 3, opens the Print() loop.
"i="
Char(i));
The For() loop then repeats until the value of i is less than or equal to 5, continuing and printing only when i is equal to or greater than 3.
Ends the loop.
