Scripting Guide > Three-Dimensional Scenes > Change the 3-D View
발행일 : 03/10/2025
Change the 3-D View
One of the advantages of creating a 3-D scene is the ease that they can be viewed from different angles and positions. The Translate and Rotate functions let you set the position from which you view the scene.
In addition, you can use the ArcBall function to enable the user to change the viewing angle interactively.
This section is about the following topics:
• Translate Function
• Rotate Function
• Look At Function
• ArcBall
• Rotate Function
• Look At Function
• ArcBall
