Scripting Guide > Efficient Scripts
발행일 : 03/10/2025
Efficient Scripts
Tips for Writing Scripts That Run Faster
This appendix provides ideas for writing JSL scripts that run faster and more efficiently. For example, it is possible to control how much time is allocated to finding an optimal design. You can collapse outlines in a report that are not necessary. Or you can write static matrices, which is faster than developing them dynamically.
Contents
Use Matrices
Design of Experiments Options
Script Data Tables
Script Graphs and Display Boxes
Script Numbers, Strings, Arrays, and Lists
Programming Tips
Troubleshoot Scripts
