발행일 : 03/10/2025
Find Missing Data Patterns
If your data table contains a lot of missing data in different columns, you can use JSL to see whether there is a pattern in the distribution of the missing data relative to the different columns.
dt << Missing Data Pattern( // message to data table
	Columns( :miss ), // find missing data in this column
	Output Table( "Missing Data Pattern" ) // name the output table
