발행일 : 03/10/2025
Hover Labels
When you hover over a visual element in a JMP graph, usually you see a basic description of the data point on a hover label.
You can customize what appears on the hover label using the following methods:
• Add Rich Text to Hover Labels Using Textlets
• Add Graphs or Images to Hover Labels Using Graphlets
• Update Names and Values in Hover Labels Using Gridlets
• Create Drill-Down Graphs from Hover Labels
• Work with the Hover Label Execution Context
